I have an mkv file in which the video is encoded with x264 and the audio is encoded with EAC3. When I try playing the file there is no audio, and I've read that I should convert the EAC3 file to AC3 using EAC3to. My problem is that I can't even extract the EAC3 audio file as mkvextract does not support the format. Is there any program that will let me extract it?
Are you using the mkvextractgui ? try the command line tool directly from latest mkvtoolnix, example:
http://forum.videolan.org/viewtopic.php?p=124421#p124421
Or try ffdshow with eac3 support to convert directly to ac3, http://forum.doom9.org/showthread.php?t=129050 , and try add the ac3 in the mkv with mkvtoolnix.
And I guess there a version of mplayer video player that supports eac3 audio on same page as above, http://forum.doom9.org/showthread.php?p=1036486 -
I tried using the command line tool by following Arite's comments in the link you provided ( http://forum.videolan.org/viewtopic.php?p=124421#p124421 ). However, instead of extracting the 2nd track from my mkv file (2nd track = eac3), it just opens up media player classic and plays the file with no audio.
[MKV] Need help extracting H264 video from an MKV into an editable medium
By SinanDira in forum Video ConversionReplies: 2Last Post: 12th Sep 2011, 12:44 -
Help extracting softsub from a .mkv movie file.
By Danilux in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2008, 00:18 -
Issue with Subs after extracting MKV file
By Alucardio in forum Video ConversionReplies: 1Last Post: 27th Mar 2008, 23:39 -
By Alucardio in forum SubtitleReplies: 8Last Post: 27th Mar 2008, 23:34 -
EAC3 soundtrack
By shun in forum AudioReplies: 0Last Post: 23rd Feb 2008, 08:35
