Hi-- wanted a little help with a file I can't convert with ffmpegx. It's a .rmvb file, RealPlayer 10.1 identifies it's video codec as RealVideo 10 and audio codec as 44Kbps Audio for RealAudio. I am trying to convert to .avi using the mencoder DivX (or Xvid) preset. When I hit start, it does something for about 2 seconds, then gives me the "completed" sound, which is of course impossible, and no output file is created. The log reads:
Encoding started on Wed Oct 24 23:01:57 EDT 2007
MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x120d6705
REAL file format detected.
Of note, within the ffmpegx main window, pressing "Play" does not sucesssfully play the video-- mplayer quits unexpectedly. I am using the reallib folder pulled from the RealPlayer 10 package, copied into the ffmpegx Support directory as instructed by other threads, and I haven't had problems converting .rmvb files in this fashion, although the last one I did which I happened to still have and looked at was identified as RealVideo 9 codec. So is there a specific problem with RealVideo 10 files? Either a confirmation that there is a problem, or a solution would be appreciated, so I can either fix it or realize it's futile and quit trying.
Thanks,
dave
Ok, I figured it out. Sort of.
mplayer actually will play it, and mencoder actually will covert it, just not within ffmpegx for some reason. If I break out the Terminal and use the command line utilities, it works, but for some reason doing it within ffmpegx causes a crash. Oh well, time to learn some command line syntax.
Not able to encode realvideo with ffmpegX on MacOS SnowLeopard
By oicram in forum ffmpegX general discussionReplies: 2Last Post: 10th May 2011, 14:55 -
What tool is idea to convert the RealVideo VBR into the DVD?
By coody in forum DVD RippingReplies: 1Last Post: 23rd Aug 2008, 10:16 -
RealVideo Source to MPEG2, problems.
By mattstan in forum Video ConversionReplies: 5Last Post: 4th Aug 2008, 05:06 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 1st Aug 2007, 23:41
Remarkable...
