I started the installation process, located the downloads, entered my OSX pw clicked "Install" and I got this message:
##/bin/sh: -c: line 1: unexpected EOF while looking for matching `''
/bin/sh: -c: line 2: syntax error: unexpected end of file
Can anyone help me? I have no idea what this means.
Yes it is the administrator, there are no special charectors in my account name or password.
It's worth noting that the program boots up now... does that mean it worked LOL?
On another note I'm trying to use this to split FLV's into jpeg frames and mp3 audio. But I don't see those options provided in the output list.
Also my FLV input isn't being recognized.
If you choose Install binaries from the ffmpegX menu, and nothing is marked in red, then the binaries were installed correctly.Originally Posted by thomashillard
Not sure what you mean by jpeg frames. For clips with the Motion JPEG codec, you should turn to QuickTime Pro, as well as for many individual frame images.Originally Posted by thomashillard
You mean it says Unrecognized in the source format window, or do you get an error message?Originally Posted by thomashillard
No output: /bin/sh: -c: line 0: syntax error near unexpected token `('
By marmi in forum ffmpegX general discussionReplies: 4Last Post: 16th Jan 2011, 09:14 -
ffmpegX won't convert files due to "syntax error near unexpected token"
By JayEm in forum ffmpegX general discussionReplies: 1Last Post: 15th Feb 2010, 17:26 -
Installation error
By johnsonk in forum ffmpegX general discussionReplies: 2Last Post: 14th Aug 2009, 11:05 -
vegas 6.0 installation error
By scd250 in forum Software PlayingReplies: 3Last Post: 27th Feb 2008, 21:09 -
Installation error -
By ruggerjvd in forum ffmpegX general discussionReplies: 4Last Post: 12th Nov 2007, 09:06
