Help anyone,i edit my ntsc video in avid xpress pro 5...i otput the video as .dv file /avid codec.I can burn a dvd out of it using nero7 or tmpgenc.2 problems.I can't create chapters.it goes all crazy,when i try to select chapters it mixes up the video,like it would put the footage from the middle in the beginning etc.2nd ,the audio on the dvd burnt with nero is a bit behind.when i preview this .dv file in vlc seeking doesnt work.i didnt try burning with tmpgenc but i dropped the file in it to c if i can set the chapters...no i cannot.i did output it as qt reference and burnt a dvd with tmpgenc but the video quality is worst than burnt from .dv file.help!
what tmpgenc are you talking about? tmpgenc plus? tmpgenc xpress? tmpgenc dvd author?
dvd author...and?(but the same thing happens in nero and probably any other prog.)
DVD Flick & AVStoDVD issues ...
By iCaptainChaos in forum Video ConversionReplies: 2Last Post: 9th Aug 2011, 11:19 -
Multiple audio, subtitles, OGM, MKV & RMVB issues
By bkfng in forum ffmpegX general discussionReplies: 12Last Post: 17th Jan 2011, 00:05 -
store video & also burn chapters according to datestamp (vista & dv
By Nicola-Pickle in forum Newbie / General discussionsReplies: 2Last Post: 4th Apr 2009, 08:08 -
Having Issues with Audio Sync when merging part 1 & 2
By DVDNewb in forum Newbie / General discussionsReplies: 8Last Post: 22nd Mar 2008, 03:00 -
Toshiba DVD players & -R media issues??
By videobruce in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Nov 2007, 07:02
