Is there a DVD authoring program out there that can do the following?
1. Natively import AVI files, to avoid the trouble of conversion
2. Produce AC3 audio, to eliminate bloat
3. Use only one built-in MPG conversion, to avoid degrading the video more than necessary
4. Shrink the MPG internally to fit the project, to avoid running DVDShrink and using yet another MPG degradation
I have an older TMpegEnc program but it does not import AVIs, forcing me to deal with the MP2+AC3 mess. I looked at their latest version here and, unbelievably, it does not support any sort of AC3 conversion to pare down the bloat.
Am I asking for the holy grail?
Tim
ProbablyAm I asking for the holy grail?
No decent tool requires step four. Step four is only required is step three is done incorrectly.
Goo authoring tools have no need to encode as all assets should be prepped before authoring.
If you are looking for good all-in-one conversion and authoring tools then you either get average encoding, or average authoring. TDA3 probably has the strongest authoring capabilities, however if you needs are modest, you might also consider
ConvertXtoDVD
FAVCRead my blog here.
Ulead Movie Factory or Ulead DVD workshop ..
Both have minor editing ability and whole bunch of other features. MF locks you into templated menus.
Authoring tools used in Hollywood
By sampalmer21 in forum Authoring (Blu-ray)Replies: 4Last Post: 9th Nov 2009, 16:38 -
help converting 2Tb of videos to H.264 (size/quality/tools)
By Prophes0r in forum Video ConversionReplies: 3Last Post: 14th Aug 2009, 00:05 -
Command line tools for dvd authoring
By sumit_pankaj in forum Authoring (DVD)Replies: 3Last Post: 22nd Jun 2009, 15:42 -
AVS DVD Authoring tools
By jimlong in forum Authoring (DVD)Replies: 1Last Post: 13th Oct 2008, 22:13 -
usefull dvd authoring tools for linux
By savignien in forum LinuxReplies: 1Last Post: 12th Jun 2007, 05:21
