i burned a dvd on 2x speed but it keeps freezing and jumping. as far as i know it is the only dvd of mine that does that, what am i doing wrong if the other are the same? can any one help? thanks
Have you tried different dvd media ? www.nomorecoasters.com
Reburn on a new dvd media and see if it works better. Maybe you just got a bad dvdr media. And be sure to always buy "quality" dvd media.
That's the brands. The quality of the media is determined by the manufacturer, indicated by the media ID. Use DVD-Info pro or equiv. to find the media id/manufacturer.imation dvd+r and sony dvd-r
/Mats
help jumping from SD to HD
By blacktooth in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 4th Feb 2012, 02:46 -
Why are my authored dvd movies jumping from one scene to another?
By KJ2009 in forum Authoring (DVD)Replies: 1Last Post: 26th Feb 2010, 03:19 -
DVD scenes jumping out of sequence
By click50 in forum Newbie / General discussionsReplies: 4Last Post: 8th Dec 2009, 01:38 -
Gui dvd author-jumping movie in fast motion scenes due to high video bitrat
By extent in forum Authoring (DVD)Replies: 8Last Post: 19th Feb 2009, 08:30 -
Jumping Text on Motion Menu in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 21st May 2008, 08:32
