Help new to burning movies. I hope someone can help me? I burn a video . Everything seems to go well. Then my CD player thells me playback feature not availible on this disc . Any Idea what I am doing wrong ????
Thanks for the help !
	CD players can't play movies.
 Please give us MORE information what you are doing,
 what video files are you burning?
 what tools are you using?
 are you converting to dvd-video?
 cd player? or do you mean dvd player?
	I downloaded and avi file from Bt junkies. Burn it to disc. It will not play back on my dvd player. Using Nero 7
	We still need more information to be able to determine what's wrong,
 Did you burn it as a data disc, just the avi file on a cd or dvd? or did you make a dvd-video with nerovision, you should then see a VIDEO_TS folder on the dvd?
 Does your dvd player support divx?
 Easiest is to use ConvertXtoDVD and convert to a dvd-video and burn and it should work on most dvd players. If your player supports divx be sure that your avi is a DivX first, you can identify it with gspot.
  Burning movies with subtitles?By legenderycity in forum Authoring (DVD)Replies: 10Last Post: 2nd Apr 2014, 02:25
  back to burning moviesBy ford10000 in forum Newbie / General discussionsReplies: 15Last Post: 25th Jan 2009, 02:38
  Online Movies, Burning to DVDBy tealmarlin in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2008, 18:42
  help burning movies?By pbure0110 in forum DVD RippingReplies: 3Last Post: 31st Dec 2007, 02:43
  burning 3 movies in a DVDBy hackerzlab in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2007, 17:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
