somewhat new to this so forgive me,anyways,I put my information into the calculator and noticed the advanced tab.....i have a question about the information in light gray that says mpeg/author overhead.If i do not use as much overhead when authoring as this mpeg/author overhead shows,can i safely add to the maximum calculated bitrate?Example..... it shows 166mb,what if i only use 69mb when i author......can i add say 50 kbps in addition to the max bitrate calculation that i get in this case?meaning it says 9603 maximum can i safely use a rate of 9650 kbps?
	Why risk it?
 1) Those 47 kbps (0.5%) extra wont make any visible difference.
 2) Don't fill your disks to the brim. If the media isn't 100% error free, it's the outer edge where the problems will show. Avoid that area.
 /Mats
	Also, there are many reports of older and/or cheaper players being unable to read from burned DVDs at the maximum allowable bitrate, leading to many here recommending using a bitrate as low as 8400 as the maximum. I usually go higher, but rarely would the combined bitrate top 9000 kbps. Read my blog here.
	Unlikely. Even authoring without menus adds something like 92MB/full DVDR5 (in DVD folder format) to original MPEG files' size.Originally Posted by mrgain
	thank-you very much for all the input you guys have been there done that so i figured its better to ask.
  Command Line avi bitrate calculatorBy M3mbr4n3 in forum Video ConversionReplies: 9Last Post: 23rd Mar 2011, 16:37
  What is the best Bitrate Calculator ?By Simmons in forum Video ConversionReplies: 6Last Post: 15th Jan 2011, 09:08
  bitrate calculator for multiple audio?By ecc in forum Video ConversionReplies: 4Last Post: 4th Sep 2008, 21:25
  bitrate calculatorBy pcb in forum Newbie / General discussionsReplies: 9Last Post: 1st May 2008, 12:34
  Real media Bitrate calculator?By ViB in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2007, 14:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
