I have a bunch of RMVB files and I am unsure of how to convert these to a file which I can then burn to a dvd which I can play on my home dvd player. Basically I am asking two questions:
1. What file format do files need to be in to burn them to a DVD so it will play on my home dvd player and
2. How do I convert a RMVB file to this type of file.
Thanks for any help you can provide
A regular, not Divx compatible, DVD player uses the DVD format. Look to the upper left on this page for 'WHAT IS' DVD for the format and specifications.
RMVB is particularly hard to convert to DVD., especially without having sync problems. You can try SUPER or there are a few programs like ConvertXToDVD that might be able to convert it. Some guides: https://www.videohelp.com/guides?searchtext=&tools=&madeby=&formatconversionselect=RM+t...or+List+Guides -
Depending on the type of software you have for making dvds, it might allow you to input rmvb files to make the dvd. If not then you probably want to convert to mpeg, avi, or wmv. Some programs that could allow for this are these.
http://biggmatt.com/programs/video-converter/winff---free-video-converter.html
http://mediacoder.sourceforge.net/
http://alltoavi.sourceforge.net/
http://winmenc.blogspot.com/
burn RMVB file to DVD to play on standard DVD player
By samoyed in forum Newbie / General discussionsReplies: 8Last Post: 14th Mar 2009, 21:29 -
Will a blu ray disk play on regular dvd player in 480 lines of resolution?
By donfm in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2009, 06:00 -
Can you burn Xvid files to DVD so they will play on stand alone DVD Player?
By JoeBolden in forum Newbie / General discussionsReplies: 4Last Post: 3rd Aug 2007, 16:48 -
Whick dvd player with usb port can play rmvb file?
By haitang in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Jun 2007, 00:31
