i have a large video file (avi) and i want to cut off the first 10 seconds from the beginning. is there any software that i can get that will do this without any loss in quality?
It depends what you mean by 'AVI'. That's just a container name. There are dozens of formats included from DV to Xvid. But I would try VirtualDub. It has lots of guides available and works for most any AVI type format. And it's freeware.
BTW, I locked your duplicate post. Please read our rules before posting.
And welcome to our forums.
Virtualdub in smart render mode.
The new experimental version ( 1.7.X ) can do some pretty interesting stuff including frame accurate editing in smart render mode.
It can now handle VBR audio (even though the error message is still there) which seemed to be a major issue with a few posters. With the addition of a few file type plugins, it can now open WMV, MPEG-2, QT and FLV. Hopefully, a H264 plugin is soon to follow.
Some filters can be used in Blend mode with the Curve Editor to make transitions.
The latest test version can be downloaded from here...
http://www.virtualdub.org/beta/VirtualDub-1.7.X-test3.zip
and you can find out about the plugins in this thread...
http://forums.virtualdub.org/index.php?act=ST&f=7&t=14639&s=81bb99e4a30be1b5f81957690fcdbf10
Cutting a H.264 file
By jairovital in forum EditingReplies: 24Last Post: 20th Sep 2010, 18:57 -
I have an issue with cutting a portion of an avi file.
By darksniper in forum EditingReplies: 4Last Post: 9th Oct 2009, 20:23 -
Cutting an mkv file
By CheekyKid in forum EditingReplies: 0Last Post: 14th May 2009, 11:48 -
Cutting a MPG FILE
By peekayem in forum EditingReplies: 3Last Post: 16th Mar 2008, 09:06 -
cutting an AVI file
By ethandeitrich in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2007, 00:03
