Say I do a 2-pass encode with the settings (2000,6000,9800) and (2000,6000,7000). Since the maximum is lower on the second example, will I be left with more space on the disc? Or does it only depend on the average bitrate? Several calculators I've tried always lower the maximum bitrate, when increasing running time, so I assume this creates more space?
since you are telling the encoder to try to average 6000 on both, the end result should be about the same size. the closer you bring the minimum and maximum to average the closer to a CBR encode you get.
HotFile Maximum Storage Space
By hech54 in forum Off topicReplies: 0Last Post: 9th Apr 2012, 08:52 -
Problem with Megui Maximum bitrate
By yaoyao0204 in forum Video ConversionReplies: 2Last Post: 17th Feb 2012, 11:57 -
Maximum Bitrate
By unity2 in forum Authoring (DVD)Replies: 17Last Post: 24th Jun 2011, 08:25 -
Nerovision maximum bitrate
By whenloverageswild in forum Authoring (DVD)Replies: 6Last Post: 11th Oct 2007, 09:40 -
Maximum Safe Bitrate
By SCDVD in forum Newbie / General discussionsReplies: 8Last Post: 21st Jun 2007, 23:37
