I saved about 1 3rd of an avi after it was edited with virtual dub. whne I play it though it was very choppy. why is this happening?
I suspect you used the default Video -> Full Processing mode without selecting a compression codec. That would give you a very large uncomrpessed RGB file which can't be read off the hard drive fast enough to play smoothly.
If you're just cutting out parts try using Video -> Direct Stream Copy mode.
AC3 to MP3 in AVI via Virtual Dub
By Simmons in forum AudioReplies: 7Last Post: 22nd May 2012, 18:16 -
MKV to AVI in Virtual Dub With AviSynth :?: :!:
By ineedhelp123 in forum Video ConversionReplies: 28Last Post: 21st Jul 2008, 15:08 -
virtual dub logo avi too big
By forchristians in forum EditingReplies: 5Last Post: 20th Sep 2007, 22:47 -
AVI to DVD w/ Virtual Dub
By hawsonggook in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2007, 01:58 -
I can't join two avi files with Virtual Dub
By Hopalong Cassidy in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 16:21
