    Mar 2007
    Egypt
    hello
    i try to convert video file to wmv ... i used WME & VLC .. WME provide much better quality ... pixels , many square over the picture with VLC Specially in sport video .. i used 128K for video , 12.5 frame-rate
    the source
    http://osragate.com/vlc/rec.mpg
    WME file
    http://osragate.com/vlc/wme_128_12.5.wmv
    VLC file
    http://osragate.com/vlc/vlc_128_12.5.wmv
    i try wmv1 , wmv2 in vlc
    WME used wmv8
    do i have to change something in vlc setting ?
    i ask in vlc irc but they did not reply
    sorry for my bad english
    thanks
    Apr 2004
    Miskatonic U
    They are very low settings, so I would expect low quality output. WMV is a closed source codec, and while some can mimic it, none seem to be able to get results as clean as WME. If you have WME, why not use it. If you are going to squeeze the living crap out of your video, you want to use the best version of the encoder possible, and that (for WMV at least) is WME.
    Read my blog here.
    Mar 2007
    Egypt
    thanks for reply
    https://forum.videohelp.com/topic338621.html
    Apr 2004
    Miskatonic U
    It's easier to understand the problem if you keep the posts in a single thread . . . .
    Read my blog here.
    Mar 2007
    Egypt
    hi
    the other thread for use WME
    but i want to enhance the quality with vlc in this thread
    when u told me why not use WME i give you other link
    Mar 2007
    Egypt
    any reply ?
