Yesterday, I decided to go to Download.com and downloaded the 30-day free trail of Adobe Photoshop CS3, so I could finish a school project.
However, when I opened the Photoshop folder, I found all these other folders holding all these files, and not a single one of them had Adobe Photoshop CS3 itself, so I couldn't use it since I couldn't find it there.
What do you all think is the problem is?
You should download it from the adobe.com site directly.
Well, I downloaded it from the Abode website, but I still have the same problem.
I can't find the main program. There are three folders in the Photoshop folder. One says "payloads," another says "redist," and the third one says "resources."
Which one of these three folders contains the main program for Adobe Photoshop CS3? -
The installation program should create shortcuts in the Start menu. Are you sure you have the actual program?
Google is your Friend -
OK, I guess I didn't check the Start menu.
Well, this is a 30-day trial, so if I have any issues with it, I'll be sure to ask other questions.
Download recorded meeting(using Adobe Connect trial edition)
By p_s_92 in forum Newbie / General discussionsReplies: 0Last Post: 17th Nov 2011, 18:41 -
Picture as Menu Background in Adobe Photoshop
By boofer in forum Authoring (DVD)Replies: 3Last Post: 16th Oct 2008, 01:41 -
Adobe Photoshop Elements 6
By Mållgan in forum Capturing and VCRReplies: 0Last Post: 2nd Aug 2008, 04:15 -
Akamai Download Manager/Premiere CS3 Trial,
By havash in forum Newbie / General discussionsReplies: 0Last Post: 23rd Dec 2007, 01:44 -
Download Adobe Premiere CS2 trial?
By Mark001 in forum EditingReplies: 1Last Post: 16th Jun 2007, 05:37
