I am trying to play an apparently damaged avi. In VLC, the video plays for about 25 seconds and shuts down. In GOM, its about 10 seconds. Zoom Player just crashes.
I cannot get it to load in VirtualDub. I get the following warnings, and it doesn't load (even though the file name is displayed in the window title bar):
[!] AVI: Index not found or damaged -- reconstructing via file scan.
[!] AVI: Keyframe flag reconstruction was not specified in open options and
the video stream is not a known keyframe-only type. Seeking in the video
stream may be extremely slow.
It will load into Gspot, but will not render in the Proposed Codec Solutions and Tests window.
Step 1 (under GSpot Vid) proceeds OK without errors, but step 2 gives a:
"failed to connect Output pin" error for the DivX and XVid steps (sorry, gspot does not allow me to copy and paste the text)
At this point I don't what else I can do.
Any ideas to extract the video (it doesn't have to be avi) or otherwise play the file?
Thanks!
When you open the file in VD, look to the bottom left of the open window and you should see a check box for 'extended options'. Click that, and select your video and a new menu will come up for re-indexing the file.[!] AVI: Keyframe flag reconstruction was not specified in open options and
But many times a corrupted AVI isn't salvageable.
OK, VD just crashes trying the re-index options. <sigh> Guess I am SOL on this file...
Corrupted/damaged video file .avi
By aizen in forum RestorationReplies: 8Last Post: 31st Jan 2012, 14:17 -
Help with damaged avi - audio/video resync
By hibbs in forum EditingReplies: 5Last Post: 16th Jun 2011, 23:20 -
Fixing / Repairing a MJPG AVI video
By DBennett in forum RestorationReplies: 6Last Post: 19th Dec 2010, 08:24 -
HELP! Need help fixing damaged mpg files - irreplaceable home movies!
By GoleeMD in forum Newbie / General discussionsReplies: 11Last Post: 22nd Apr 2009, 21:28 -
VLC and damaged .avi
By christopheramos in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2008, 13:14
Blank out the file and pathnames, if you prefer.
