I am a newbie and I tried using virutal dub and I was just fiddling with a video file. I must have done something because now whenever I play it out of virtual dub even after deleting and redownloading it in the top-left corner there is text like
Audio track:
Input description 48000 Hz, stereo 128kbps mp3 (libmad)
current input rate: 128 kbps
Please tell me how to get rid of it!
So, it happens no matter which player you use to play that AVI? It could be something that you enabled in a codec. Does it happen if you play the AVI using a player that uses its own codecs, like VLC or mplayer?
(TJohns: I was suspecting it might be ffdshow, too, but I'd never seen its OSD in action... and figured I should be sure of everything else, as well.
If cameras add ten pounds, why would people want to eat them? -
It sounds like ffdshow OSD, Start -> Programs -> ffdshow -> Audio decoder configuration and uncheck OSD. If you have don't have the ffdhow in the Programs menu you should see a ffa icon in the tray/notification area when you play the video, just click on it to to bring up the configuration.
edit:I'm too slow.
Extra video top and bottom; black bars left and right
By koberulz in forum Newbie / General discussionsReplies: 27Last Post: 15th Oct 2011, 15:14 -
mpg file went burnt to dvd plays only in top left hand corner of tv
By johnkane1 in forum Video ConversionReplies: 0Last Post: 9th Feb 2009, 10:16 -
DVD Recorder - Black Boxes On Right And Left And Down And Top
By Stefan1826 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 12th Apr 2008, 05:17 -
DVDFab and subtitles (getting black square at top left)
By respondtome in forum DVD RippingReplies: 2Last Post: 3rd Apr 2008, 08:53 -
Editing an AVI file so I am just left with the VIDEO Avi (No Audio)
By incrediblej in forum EditingReplies: 6Last Post: 26th Mar 2008, 20:16
