    Apr 2007
    Bahrain
    Hi , How are you doing , I hope fine
    I got a simple problem here ,
    When I play a video with a small resolution , so that it become maximized to fit the window , it become a bit sharp ,
    also if I watch some channels on the satellite card , the same thing happen , sharp video . I'm using windows vista , and I used to the videos in XP that they're softened when they're maximized , but that thing isn't happening with me now , I sure there is some thing to do with the configurations .
    So , is there any way to soften the ( Now playing ) video ??
    Thats an example .
    Look at the logo of the channel and the result line , they're a bit sharp
    Do not think that the channel isn't very clear , no , that happens with the other videos . Some channels are clear , because their size fit the screen and they aren't getting maximized . But this channel does not , and its maximized .
    So it all has to do with the maximization , see ?
    So , ANY ANSWERS PLEASE
    thanks alot ,
    & goodbye .
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Are you using the same media player or a different one? Different players often display differently. You typically have to adust the video settings within the player. Also, some codecs allow you to adjust the video settings.
    Google is your Friend
