Can Adobe Premiere do a lot more than free programs like AVIsynth? I was just curious if it's worth buying and learning to use if it makes better menus, has better effects, and more capabilites. If not then I'd stick with the free programs or cheaper programs.
Just test the trial of Premiere CS3 from http://www.adobe.com/downloads/ (you need a adobe account).
Premiere Pro is intended for original production. If you are starting from scratch with camcorder video and graphics and intend to make a complex video, Premiere Pro will be much more productive. Learning curve is steep but then so is avisynth.Originally Posted by jwfc
Check out Vegas for similar features that are more intuitive to learn.
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
.VOB>adobe premiere 6.5
By IT learner in forum EditingReplies: 1Last Post: 20th Sep 2011, 07:43 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17 -
Adobe Premiere CS3 vs 2.0
By hanugro in forum Video ConversionReplies: 0Last Post: 31st Aug 2007, 07:26 -
How does Adobe Premiere 2 rate
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 21st Aug 2007, 23:08
