What is the best free software out there that can compress DVD9 To DVD5? i tried to copy dvd9to dvd5(4.7Gig) using dvd shrink, decrepter, ripit4me and still not work. keep showing red on the bar that tell me it is to big to burn. any help would be appreciated.
DVD Shrink is the only one of those mentioned that can reduce size, but it is limited in what it can do. If you want to keep everything, then you will have to compromise quality. This means running it through Shrink once, then taking the results and running it through Shrink again.
Better quality can be obtained by using DVD Rebuilder with the free encoder HCEnc. Use the installer and everything will be set up for. Sacrifice quality in the extras by choosing half-d1 for extras and get a better quality main feature.
Or use a combination of the two. Use Shrink in re-author mode to take just the main feature (no extras, no menus) and see if it fits on a single layer disc. if it doesn't, and only misses by a small amount, let Shrink reduce the size. If it still misses by quite a bit, write the results to your HDD, then use DVD Rebuilder to reduce the size.Read my blog here.
DVDFab Decrypter to rip to your HDD and run it through FiXVTS and last shrink with DVD Shrink.
But some dvds are still a bit too big for dvd shrink but try remove audio tracks, extra material and such. -
Thank you for your help and i will try those again see if it'll help me
DVD9 to DVD5
By roflwaffle in forum DVD RippingReplies: 5Last Post: 3rd Nov 2010, 16:52 -
DVD5 vs. DVD9
By Beaker14 in forum DVD RippingReplies: 1Last Post: 6th Nov 2009, 10:33 -
DVD9->DVD5, Best results?
By indijay in forum DVD RippingReplies: 27Last Post: 15th May 2009, 10:34 -
DVD9 VOB To DVD5
By ConbuD in forum Newbie / General discussionsReplies: 5Last Post: 11th Jun 2007, 22:20 -
dvd9 to dvd5 using dvdshrink
By rancid in forum DVD RippingReplies: 7Last Post: 14th May 2007, 21:52
