Hi,
My question is how do you convert MPEG-4 into MPEG-2 format? Is there any good mac freeware or shareware (freeware is best if possible) that can convert MPEG-4 into MPEG-2?
Thank you for taking the time to read this.
Results 1 to 13 of 13
no freeware, everything good is going to cost, from the
$15 ffmpegx to the $30 MpegStreamclip
( the cost of the Mpeg-2 Component), to the $24 Visualhub.
stop thinking in terms of FREE and start thinking in terms of
SIMPLICITY and EASE OF USE. *shrugs* becasue that
is really what you should be worried about.
Too often people want "free" but then want to come here and
tell us they are pulling their hair out trying to make "free" work.
When the answer we usually give them is " go pay for/buy this
piece of software, get it done with less hassle."
skip the middle man, just go buy one of the above I mentioned."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Thanks for the shareware suggestions and help. I will do some research on them. As you say, ease of use and effectiveness are the most important points I should look for in a program. I was asking to see if there was another awesome freeware like MPEG Streamclip; however, if there isn't, I don't mind paying some money for a good quality program like MPEG Streamclip. I think I might try the MPEG-2 component. I know MPEG Streamclip works very well.
MPEG Streamclip won't to MPEG4-->MPEG2, only the other way around.
Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh? -
Really? So even if I buy the MPEG-2 component for MPEG Streamclip, I can't convert MPEG-4 to MPEG-2?
Urban Mac User -
Thanks for all the help. I am now using FFmepgx, and I am LOVING it. I am having a blast with it and sizzle. The coolest part is when I use the DVD mpegenc option I also get an audio file of the video among other things, so I can use it with sizzle. Can't wait to test out the other options.
Yes, VLC is indeed a wonderful piece of software. Most people only know it as a player, and don't realize that it has quite an array of transcoding abilities as well. Thanks, mhar4, for posting a reminder to that effect. VLC is free, simple and powerful. Can't ask for much more than that!
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Convert mpeg-4 to mpeg-1 with ffmpegx?
By CollinH in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 23:36 -
Mpeg-4 to mpeg-2 for mac/adobe premiere pro......
By macbookuser in forum Newbie / General discussionsReplies: 1Last Post: 4th Sep 2007, 22:48
