Is there a way to import a picture into AVIsynth? I wanted to make a title page and insert some jpegs into my video and I couldn't figure out how or find a post on it. Thanks!
	Yeah, what you actually want is a little unclear to me, but how about:
 ImageSource("C:\Path\To\Picture.jpg")
 http://avisynth.org/mediawiki/ImageSource
	Yeah I want to do both importing a picture, which it looks like ImageSource does (thanks for the help  ), along with the video I took from my digital camera. ), along with the video I took from my digital camera.
 And then I also wanted to create a title page for the video. Like if I made something in Photoshop and then imported it in somehow.
 In that reference about ImageSource, I don't understand what the use_DevIL means. It says it will bypass the internal parser if set to true. What is the reason we should or should not do this? Thanks!
	I still don't understand. Do you know and understand AviSynth? And that ImageSource page didn't help? What do you want to do? Can you be more specific? Do you just want to have the still pic for a certain amount of time, followed by the video:Yeah I want to do both importing a picture, which it looks like ImageSource does (thanks for the help ), along with the video I took from my digital camera.
 A=ImageSource("C:\Path\To\Picture.jpg",End=300,FPS =29.97)
 A=A.ConvertToYV12()
 B=MPEG2Source(C:\Path\To\Video.d2v")
 A+B
 That'll display the pic for 300 frames (10 seconds at 29.97fps), followed by the video. If the video is in the YV12 colorspace, the pic has to be converted to the same. I'm assuming the video in an MPG of some sort and you've created a D2V project for it using DGIndex. Maybe it's an AVI, in which case you use AVISource, and maybe the colorspace doesn't have to be converted. The picture and video have to be the same resolution, or one or the other has to be resized. Test out your scripts in VDub(Mod) to get understandable error messages.
 I still don't understand what you mean by creating a title page. Are you talking about a menu, like for a DVD?
 Ignore the DevIL stuff. You'll never need it.
	Yeah for title page I meant like title of my video, but not necessarily a menu to navigate, although that would be cool. Seeing how I cannot get basic functions to even work, I will do that at a later time. But just out of curiosity, can I use TMPG Author to do that after I make my video? Is that the best way?
 So for my title, it would be just like a slideshow, some black screen that said, "boat race 10/20/07" or something like that. I figured I could create something in photoshop, save it as a JPEG, and import it in with ImageSource.
 I had this in my script:
 a=DirectShowSource("myfile")
 b=ImageSource(file="myPicture")
 a+b
 and I got the error that my video had audio and my picture didn't. So I then did
 bAudio=WavSource("some random .wav I found on my computer")
 c=AudioDub(b,bAudio)
 a+c
 then I got the error that video formats don't match. The size of my picture is the same size as my video. Any advice here? Thanks!
	OK, I think I understand about your title page. It's more commonly called (if for DVD) a First-Play video. Something that plays before going to the menu or to the main video, often a logo or short intro. I don't use TMPGEnc DVD Author, but I've read it can do that easily enough. Me, I've added in a First-Play before, after authoring, by using PGCEdit's Title->Import DVD's First-Play (Startup) Clip.I use TMPG Author to do that after I make my video? Is that the best way?
 DirectShowSource, why do people use it? First, make sure your AviSynth is up-to-date. Then it's less likely that DirectShowSource itself is the problem. Then, to make sure the audio isn't the problem, disable it entirely:
 a=DirectShowSource("myfile",Audio=False)
 Then, as for video formats not matching, make sure the color spaces are the same, as I advised earlier. If you don't know what they are for the 2 sources:
 Info()
 and then do it for the other. The framerates for the 2 have to be the same as well, as I also tried to make clear in my earlier post. If you insist on using DirectShowSource, you sometimes have to set the framerate. The Info line will also give you the framerate for the 2 sources.
 http://avisynth.org/mediawiki/DirectShowSource
	I used Info() to find the Info on my picture and it said, "RGB24." I then tried a=a.ConvertToYV12(), but it gave me the error:
 "The script's return value was not a video clip"
 Any advice? Thanks.
  Getting Avisynth to import raw avi without converting to RGBBy Asterra in forum Video ConversionReplies: 18Last Post: 22nd May 2011, 21:08
  .mp4 Avisynth import issuesBy Campony in forum Video ConversionReplies: 29Last Post: 20th May 2011, 09:11
  How do I zoom out and move picture with avisynthBy xicudiz in forum EditingReplies: 6Last Post: 31st Mar 2011, 18:28
  Picture in Picture AvisynthBy praetorianprefect in forum EditingReplies: 2Last Post: 5th Jun 2009, 10:26
  Avisynth Picture in Picture Script Slows Down Video and Lacks SoundBy OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 21:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
