I'm ultimately trying to convert a .tivo file to a .mp4...(since I dont thinnk there is anyway to do that while keeping its original resolution-tivo desktop only converts it for ipod w/ 320x240)....I'm using this guide to convert it to mpeg2 (w/ a .mpg extension) http://www.basementnerd.com/tivo.htm
all goes well with that...but when I try to convert the .mpg to mp4 (im using Super to do that)...the audio is slighty out of sync...and it gets a little worse a bit of the ways iinto the show
does anyone know the apporpriate codecs and settings (bit rate, fps, etc..) to use w/ super to sucessfully convert an mpeg2 to an mp4 ..w/ out any audio sync issues??
here are the specs of my .mpg file
Video : 1.54 GB, 3700 Kbps, 29.970 fps, 480*480 (1.0:1), = Elecard MPEG-2 Video
Audio : 82 MB, 192 Kbps, 48000 Hz, 2 channels, 0x50 = Mpeg-1 audio Layer 2 (MP2)
any suggestions/help would be appreciated
thx
	"Fix" the mpg with Videoredo using the quickstream fix before you convert it. I guess you can try run it through pvastrumento or projectx also if you are looking for free tools.
  How can I convert a mpeg2 and ac3 file set into a mp4?By woppyvac in forum Newbie / General discussionsReplies: 10Last Post: 5th Apr 2012, 09:01
  Audio out of sync on MP4 fileBy adamf154 in forum AudioReplies: 3Last Post: 26th Feb 2010, 08:15
  Fixing audio sync issues when using GOTSent to convert MKV to MP4By darrklight1138 in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2009, 07:56
  Audio out of sync on MP4 file. Fixable?By liverkick in forum Video ConversionReplies: 2Last Post: 26th Feb 2008, 15:01
  trying to convert an Xvid avi to mp4 w/ SUPER. audio is out of sync!By cduval04 in forum Video ConversionReplies: 3Last Post: 10th Oct 2007, 19:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
