The movie plays fine at the beginning there is sound but 5 mins into it the sound goes out i can hear music in the background and in one scene crickets and leaves crunching, at one point a character yelled and i could hear it but it was extremely low. any ideas?
	What sort of movie ? Is this a DVD, an avi file ?
 If it is an avi file, what is actually in it ? The contents of an avi file are packed using codecs. MP3 is a codec. AC3 is a codec. What format is the avi. G-spot or mediainfo will tell you.
 Is all the audio low, or is it just the vocals ?
 Did you create this file yourself, or did you acquire it elsewhere ?Read my blog here.
	its avi. video codec is xvid, sound is AC3 says under stat codec installed, i used GSpot. i downloaded as a compilation file the entire file is not done yet but this file is 100% complete. it appears that only the vocals and sound effects are gone however i hear music and i know that the sound is there its just really low
	2 channel AC3 or 5.1 ?
 If it is 5.1 then it maybe your codec and the way it is downmixing.
 If it is 2 channel then it is most likely how it was downmixed by the person who encoded it originally, and there is very little you can do to change it.
 Open the file in VLC, and then click on the Audio menu. There should be an option to choose the number of channels. If 5.1 is available, choose it an d see if it sounds better. If it is a local downmix issue then it should sound better under VLC anyway, as it will bypass your other codecs for playback.Read my blog here.
	You might be missing some codecs on your system. www.free-codecs.com under K-lite full codecs should do the trick. It's free... VLC is for streaming the media around, but does make a good media play too.Originally Posted by hardtime Best Regards, Best Regards,
 Tipstir
 MediaMVP Supporter
  Editing AVI movie with avidemux resulted in distorted sound. What can I do?By johnharlin in forum EditingReplies: 2Last Post: 29th Jul 2011, 17:49
  Windows Movie Maker: AVI's sound bad, MPEGs won't playBy Canopus Smoker in forum Newbie / General discussionsReplies: 3Last Post: 26th Nov 2008, 11:54
  DV-AVI widescreen 16:9 movie from Windows Movie Maker.By bagb in forum Newbie / General discussionsReplies: 19Last Post: 12th Nov 2007, 11:37
  AVI - sound with VLC , no sound Toast burnedBy BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 21:21
  DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
