Hi All,
I have a DVD with a generic SA menu screen and no chapter points. I'd like to remove the menu and add chapters (concert DVD, chapter for each track).
I've heard that TMPGEnc DVD Author is good to use but when I looked into DVD Author version 3 many people in various forums are complaining that it re-encodes already DVD compliant video. Is this true? If so, does version 2.0 or 1.6 re-encode already DVD compliant video as well? If version 2.0 or 1.6 is better and doesn't re-encode the video for what I need to do, can I still get those older versions?
Any help would be greatly appreciated!
TDA 1.6 is too simple for this, it can't re-encode. TDA3 is much more flexible but you have to disable some encoding features activated by default (encoding LPCM to AC3, encoding chapter points as I-frames etc.). It will also re-encode the last GOP of each clip (they say it's for safe joining them if someone prefers to add separate clips to the same track). It will not re-encode everything without error message. I still prefer it to DVDLab, it saves a lot of time at menu building.
problem with tmpgenc author 4 trying to re encode
By kingsley in forum Authoring (Blu-ray)Replies: 1Last Post: 19th May 2012, 17:28 -
Does reauthoring (TMPGEnc DVD Author) re-encode / degrade video quality?
By MheAd in forum Authoring (DVD)Replies: 8Last Post: 9th Aug 2010, 05:42 -
TMPGEnc DVD Author 3 can't import AVI video, only audio?
By XyBeRz in forum Authoring (DVD)Replies: 7Last Post: 31st Jan 2009, 09:54 -
New to TMPGEnc DVD Author 3 - Two Questions on Video Quality
By heyjjjaded in forum Authoring (DVD)Replies: 0Last Post: 16th Aug 2007, 12:15 -
I get 2 layers of subs on video in TMPGEnc DVD Author 3...help!
By tektaktyks in forum Video ConversionReplies: 1Last Post: 1st Jul 2007, 11:18
