I have recieved the following file from a reliable source:
birthday-retirement pics 2007 Picture 012.jpg [90_97].dat
I am unable to open this file. It is a DAT (?) of a jpeg file. Can anyone help me with a conversion program so I may open this file? It is from my aunt's retirement and I would appreciate any and all help.
TIA
I guess you have just tried renamed it to jpg and opened it?
Assuming it is an actual .dat file, you would need to know the file that was used to create it.
Google is your Friend -
Some versions of Novell mail clients use that as some sort of funky compression. Try opening the DAT file in winzip.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik
Best freeware for converting MTS to easily readable format?
By mccake in forum Video ConversionReplies: 1Last Post: 8th Dec 2011, 04:48 -
Problem converting combined motion jpeg and mp4 audio file into other forma
By Anonymous3 in forum Video ConversionReplies: 49Last Post: 31st Aug 2011, 16:14 -
Readable x264 help file
By m4Rio in forum Newbie / General discussionsReplies: 3Last Post: 9th Aug 2010, 10:06 -
Converting XPI file to something readable
By NP11073 in forum Video ConversionReplies: 1Last Post: 24th May 2010, 14:25 -
Empty file when converting vcd (.dat) format to ipod (mpeg4)
By happyriceman in forum ffmpegX general discussionReplies: 3Last Post: 5th Jul 2008, 05:19
