After coming to a conclusion that Pinnacle Studio 10 is not an optimal software for me to edit videos of my small nephew, I gave up trying for more than half a year. The resulting project is about 95 minutes DVD with complete menus, everything done. The problem with the program is that it won't create a DVD, everything tried, really a lot of free space for it to render, etc. Always stopped somewhere at 30 minutes or so of the film. Apparently, this project is too big for it?
My question is, how can I import this project into any other editing software? - I only need to actually make a DVD out of it, that's all. Without using Pinnacle again... (On the Pinnacle forum, they advised me to start over as I made some lot of mistakes, but it doesn't seem a good solution to me...)
My sister-in-law really wants to see those videos, but the only way of showing them at the moment is by starting Pinnacle on my computer
Thanks in advance!
Results 1 to 9 of 9
Exporting the video failed so many times if I understand correctly what you mean... Or you suggest starting a very new project in another tool?
If it won't even export the video then you are pretty much screwed and will have to start again. If you have made lots of mistakes - and god only knows what they might be - then you may also have your answer. Either way, it looks like you will be starting again.
I strongly suggest you look at either VideoStudio, Vegas Movie Studio, or Premiere Elements and alternatives.Read my blog here.
Maybe I don't understand you right with exporting video...? (I surely want to also export the sounds and transitions)
My mistakes were, as pointed out by Dutch Pinnacle discussion forum, updating to 10.7 while busy with the project, and messing around with gaps. -
I see. Thanks for the tip. Exporting probably also involves a lot of free disk space needed? (This also seemed to be the problem with creating a DVD)
Thank you for your advice. It seemed to work so far. At the moment I am copying a 21 GB .avi file to another computer to author it. Hope it will work too. Hope I will be able to extract audio from this resulting movie as it turned out way too loud and not synchronized.
P.S. Suppose I can delete the temp files in render folder already? (around 5 GB)
Video editing software that supports importing video with multiple audio?
By elgy in forum Newbie / General discussionsReplies: 5Last Post: 15th Nov 2011, 19:32 -
Problem importing video files to Editing software
By alistairsmac in forum Newbie / General discussionsReplies: 2Last Post: 16th Oct 2010, 12:15 -
Importing files with AC3 sound into editing software
By jeanpave in forum Video ConversionReplies: 10Last Post: 21st Apr 2010, 01:55 -
Best software for Video Editing - Nero, Roxio or Pinnacle Studio
By bpatters69 in forum Newbie / General discussionsReplies: 27Last Post: 28th Dec 2007, 22:11 -
Importing FLVs into a video editing software???
By J C in forum EditingReplies: 11Last Post: 27th Oct 2007, 20:04
