I am a total newbie when it comes to codecs and converting formats, so if someone could explain to me as if I was 4 years old, I would appreciate it
I am playing around with kyte.tv a lot and I am using my Nokia N95 mobile phone to shoot clips. The video recording in N95 is quite impressive for being a phone and since it's mobile video blogging, I have no plans of using different devices for this purpose.
Even if mobile blogging is more or less about that instant broadcasting, it is nice to be able to edit clips and join them together. N95 records in mp4-format, a format that apparently isn't supported in Premier Pro 1.5. I did convert the files using a software I found called mp4toAvi-somthing. Now, after convertion I can play the avi-files in various of media players and in FFdShow and Gspot yada yada yada (as I said, I am not good with this) BUT i cannot import them to Premier. Well basically I can, but Premier gets stuck on the "Importing Files" bar for long time. With other files the importing is almost instant, but not here.
Anyone have any ideas what can be wrong? The files I want to import are between 7-20mb big, so nothing big really
Cheers
It just change it to an avi container with same video codec and Premiere might have problem reading the video codec. Try convert to avi with another video codec like uncompressed, huffyuy, mjpeg, lagarith, etc using Virtualdub(Video->Compression, Audio->Full Processing and File->Save as a new avi), avidemux or super.
Yes, thanks. It worked well with VirtualDub and Lagarith codec. Many thanks!
Vegas Movie Studio HD 9.0 and Importing .avi files.
By empressofbees in forum Newbie / General discussionsReplies: 3Last Post: 17th Jan 2012, 16:45 -
Trouble Importing avi file into Adobe Premiere
By Top Gun in forum Newbie / General discussionsReplies: 8Last Post: 18th Jul 2010, 13:21 -
AR wrong when importing this AVI
By terrypin in forum Newbie / General discussionsReplies: 7Last Post: 14th Sep 2008, 12:19 -
Importing/Editing Video with Adobe Premier 6
By Namrepus221 in forum EditingReplies: 10Last Post: 12th May 2008, 21:30 -
Help With Premiere Pro 2 (importing Screen Captured Avi File)
By paulinnorway in forum EditingReplies: 2Last Post: 15th Oct 2007, 10:19
