When I try to convert a movie in MPEG-TS to .avi (MPEG2 to mpeg4) I have no sound in the converted movie. I try to change the channel. But no sound.
Audio is in mpeg2, 48000, 192 kb/s. An idea ?[/img]
First, you say that you have tried to change channels. I assume that you mean that you have tried several tracks (plusieurs pistes -- je regrette que mon français est si mauvais)? Try playing the original file in, say, VLC, and verify which track contains the audio you wish. Sometimes, the audio track you want is not where one would expect. [If I recall correctly, there is a numerical offset of one between the numbering conventions of ffmpegx vs. VLC.]
Also, you have options to decode with QT or mencoder. Try altering your choice to see if you obtain better results.
Bonne chance!
Conversion from mpeg to mov: the sound is unsynchronized with video
By rikintosh in forum ffmpegX general discussionReplies: 4Last Post: 8th Feb 2012, 14:31 -
Sound lost after conversion mpeg to avi
By maclinux in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2008, 14:47 -
Help keep 5.1 sound for mkv-avi conversion for Xbox Media Centre playback
By HitcherUK in forum Video ConversionReplies: 5Last Post: 23rd Oct 2007, 04:30 -
there's no sound with my mpeg-1 conversion
By darealest1 in forum MacReplies: 1Last Post: 13th Jul 2007, 09:12 -
riverpast rm to avi conversion sound out of sync
By princevegetam in forum Video ConversionReplies: 9Last Post: 2nd Jul 2007, 03:45
