I have an old 17" CRT monitor that I want to use for capturing VHS tapes and wanted to know if anybody has any recommendations on S-Video to VGA converters and if the colour recreation is accurate. Would these devices (like the Viewsonic Nextvision Nx series) be a good idea or am I better off buying a small TV? What I am mainly concerned about is if the picture and colour recreation on the CRT monitor will be any good.
Just generally, you will need to adjust the color levels, contrast, brightness, hue, etc., on any monitor if you want to calibrate it or make it similar to any 'standard'. None of them will be preset properly. There's a whole lot more to it all, but I'll let others with more expertise give you better info.
I agree it would be extremely difficult to get a good calibration on a VGA monitor suitable for color correction..
Well I am not talking about perfect broadcast quality correction, just minor enhancement. Would I be better off then just buying a decent 13" or 14" TV then (I was thinking about a flat Toshiba)? Thanks
Yes a TV will be a better reference.Originally Posted by NightFire
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 08:31 -
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 02:05 -
Video panel lost on 2nd monitor on laptop VGA port
By jeth32 in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2010, 20:08 -
Hardware advice, video card & monitor, DVI or VGA ??
By Noahtuck in forum ComputerReplies: 7Last Post: 12th Jul 2009, 00:58 -
How to play video on VGA monitor without a PC
By ari dubov in forum Newbie / General discussionsReplies: 2Last Post: 15th Mar 2008, 14:45
