i have a magnavox vcr/dvd combo and i was recording a tv show and when i went to watch the tape the audio on the tape sounded like if someone was fast forwarding through the audio. you can't hear anything from the actual tv show. the image is also somewhat distorted. i've taped with this vcr to this tape before and it was perfectly fine and you could still watch what was previously recored to the tape just not the last show. i don't understand what could be causing this. Does anyone know how this could be fixed?
If this is the only time this every happen, possibly glitch in the tape ( bend, fold, tear or Bad tape ).
i tried the tape with another vcr i taped over that part and nothing happened it sounded fine and the image was fine too. so i think it is the vcr i just don't understand why i can watch other tapes with no problem, i can even watch the beginning of that same tape on that vcr and it works fine. its just the last 2 hours that came out like that.
Try cleaning the Vcr head see if that make a difference.
I cleaned it with this special tape i have that cleans the vcr heads and i tried recording with a new tape and the audio was still the same and the image was jumpy and distorted.
Sounds like a dirty or faulty recording head. I don't know that those can be cleaned like the play heads.
Google is your Friend
Problems with capturing using ION VCR 2 PC
By mostly_useless in forum Capturing and VCRReplies: 0Last Post: 21st Dec 2011, 18:16 -
VCR to DVD problems
By airplaneman11 in forum Newbie / General discussionsReplies: 2Last Post: 1st Jan 2011, 18:19 -
Problems with JVC HR S6900U VCR.
By Video converter in forum Newbie / General discussionsReplies: 0Last Post: 9th Nov 2010, 13:31 -
VCR Tracking problems
By wetcamelfood in forum Newbie / General discussionsReplies: 12Last Post: 27th Dec 2008, 16:45 -
Having problems capturing from VCR
By Confused Chimp in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2007, 02:41
