I have a 2 hour, 29 gigabyte .dv file that plays in Quicktime.
I have a list of about 35 different cuts I want to make. Is there a way I can automate this in either Quicktime Pro, or iMovie? Or do I need Final Cut?
For example, is there somewhere I can punch in all the appropriate cut times:
2:05 - 3:09
15:32-25:01
1:05:09-1:10:11
And so on, and have 35 different quicktime files exported automatically? I want to have it automated instead of having to go through and manually cut each clip from the 2 hour long file, and export individually.
Conrad
For future reference there's a Mac forum for all questions Mac, they have their own little world. :P PM a mod to move your post.
Not sure how it works in the MAC world but I'd imgine it's the same. If by any chance those cuts are portions of the tape where you have paused or stopped recording and the timecode is intact you don't even need to mark the cuts. Each scene can be captured as a different file or exported as individual files, really don't know how any of that software works so I couldn't tell you. But if that's the case its a huge timesaver. -
it's not easy to do what you ask.
SimpleMovieX comes close to what you are trying to achieve.
I just set chapter markers in FCP, export the file to QT Movie,
and then use DVDSP to mask the chapters in a Play all script,
leaving my desired "cut".
You could look into First Cut software, which might be what you need.
search version tracker for it."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
How to use the DVD Titlename as name of file automatically
By phatz in forum Newbie / General discussionsReplies: 4Last Post: 25th Aug 2010, 19:51 -
Automatically play a video file each and every day at the same time?
By nrvsysdc in forum ComputerReplies: 3Last Post: 10th May 2009, 00:44 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 08:58 -
Automatically split a video to 2 dvds
By cd090580 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Mar 2008, 18:56 -
automatically cutting a large wav file into x minute chunks?
By graysky in forum AudioReplies: 5Last Post: 22nd Sep 2007, 23:12
