i usually use winavi (yeah i know people hate it), but i get good results when combining multiple avis, no more than 4 tho to fit on a single layer dvd
when i try to create a dual layer dvd, i burn and it just dont play right, could it be winavi, or the dual layer dvd's
if it is winavi, what prog us there that you can input more than 1 avi, and it encodes all together,
what i usually do is load the finished set of files into tmpgdvd author, and it comes up with each avi i encode as separate chapters
ive got convertxtodvd, but when i ask it to load more than 1 it create separate folders for each which is not what i want, iv e not tried loading each one into tmpgdvdauthor, last time i tried separate folders dvd author said they need to be at same bitrate (which the files from winavi were)
any help please?
DVD Flick can combine multiple avis into a single title, and will produce much higher quality output than WinAVI.
Once it is finished, use Imgburn to burn to Verbatim +R DL discs from Singapore. If you use any other brand of disc you might as well just send your money to me instead. You will get the same outcome, and I will get money. Win-Neutral.Read my blog here.
AVI Mux GUI is simple and solid for combining AVI files into one. AVI2DVD can accept multiple AVI files to create a DVD VideoTS folder or ISO.
I believe both are linked in the tools section <-----
VH
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
Multiple VOB sets onto 1 DVD?
By bcemail in forum Authoring (DVD)Replies: 3Last Post: 6th Apr 2008, 17:09 -
VOB to Multiple Avi Files
By Idlewild in forum ffmpegX general discussionReplies: 2Last Post: 25th Jan 2008, 01:41 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28 -
VOB to .ts with multiple audio tracks
By csaba1985 in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2007, 07:28
