I can turn the volume up of the receiver but then if I forget to turn it down, my other DVD karaoke will be too loud. I may have an idea how to do it but will appreciate if someone can walk me through it. Thanks.
If it is just a standard DVD, then you can demux the audio, increase the volume, then mux it back. It's not simple, but it is doable.
However, many karaoke DVDs don't seem to be standard DVDs, so yoiu may not be able to screw with it without breaking it.
This guide explains how to replace an audio track. It's not exactly what you are doing, but close enough for you to work it out. You need to do steps one and two, then for step three, you need to increase the volume of your audio and re-encode it with the same values as the original, then follow the guide from step four onwards.
Edit : Oops - Forgot the link : https://forum.videohelp.com/topic234240.htmlRead my blog here.
How to make the audio louder in an H264/AAC video
By rumplestiltskin in forum MacReplies: 17Last Post: 29th Jun 2011, 21:17 -
Can I batch process some mp3's with Audacity to make them louder?
By snafubaby in forum AudioReplies: 2Last Post: 10th May 2011, 13:24 -
I want to make the Audio in some AVI files louder
By Simmons in forum AudioReplies: 10Last Post: 26th Dec 2010, 10:22 -
How to make a karaoke VOB file from 2 (one audio and one text)?
By coxanhvn in forum Newbie / General discussionsReplies: 0Last Post: 5th Jul 2010, 00:57 -
make songs louder on ipod
By angryassdrummer in forum AudioReplies: 3Last Post: 12th Mar 2010, 11:11
