Im using a Dell Ispirion 8500 with 512 ram.
Im also trying to burn with an NEC external burner and a Maxtor external hd both on USB 2.0 ports.
I keep getting this error and getting ruined disks.
Here the log file.
Thanks Brad
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 10:20:56 AM
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 1:54:32 PM
NT-SPTI used
Nero Version: 7.2.3.3
Internal Version: 7, 2, 3, 3
(Nero Express)
Recorder: <_NEC DVD_RW ND-3550A> Version: 1.06 - HA 1 TA 1 - 7.2.3.3
Adapter driver: <USB 2.0> HA 1
Drive buffer : 2048kB
Bus Type : set to ATAPI (3) -> ATAPI, detected: ?
CD-ROM: <QSI CDRW/DVD SBW-242>Version: UD30 - HA 1 TA 0 - 7.2.3.3
Adapter driver: <IDE> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : HITACHI_DK23EA-30 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : QSI CDRW/DVD SBW-242 atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
QSI CDRW/DVD SBW-242 D: CDRom0
_NEC DVD_RW ND-3550A E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
BUFE : 0
Physical memory : 511MB (523496kB)
Free physical memory: 77MB (79632kB)
Memory in use : 84
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
19.10.2007
Burn DVD Image
6:26:19 PM #1 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 262144KB of Memory
6:26:19 PM #2 Text 0 File Reader.cpp, Line 124
Reader running
6:26:19 PM #3 Text 0 File Writer.cpp, Line 113
Writer E: _NEC DVD_RW ND-3550A running
6:26:19 PM #4 Text 0 File Burncd.cpp, Line 3400
Turn on Disc-At-Once, using DVD media
6:26:19 PM #5 Text 0 File DlgWaitCD.cpp, Line 290
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2138397 (475:11.72, 4176MB)
6:26:19 PM #6 Text 0 File DlgWaitCD.cpp, Line 302
Write in overburning mode: NO (enabled: CD)
6:26:19 PM #7 Text 0 File DlgWaitCD.cpp, Line 2733
Recorder: _NEC DVD_RW ND-3550A, Media type: DVD-R
Disc Manufacturer: MCC 02 - RG20
Disc Application Code: 64, Disc Physical Code: 193
6:26:19 PM #8 Text 0 File DlgWaitCD.cpp, Line 474
>>> Protocol of DlgWaitCD activities: <<<
6:26:19 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, Joliet)
2 indices, index0 (150) not provided
original disc pos #0 + 2138398 (2138398) = #2138398/475:11.73
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2138398 blocks [E: _NEC DVD_RW ND-3550A]
6:26:19 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [E: _NEC DVD_RW ND-3550A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4379439104, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2138398 | lead-out | 1 | 0x41 | 0x00
6:26:19 PM #11 Text 0 File SCSIPassThrough.cpp, Line 39
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
6:26:19 PM #12 Phase 24 File dlgbrnst.cpp, Line 1730
Caching of files started
6:26:19 PM #13 Text 0 File Burncd.cpp, Line 4231
Cache writing successful.
6:26:19 PM #14 Phase 25 File dlgbrnst.cpp, Line 1730
Caching of files completed
6:26:19 PM #15 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 12x (16,620 KB/s)
6:26:20 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
6:26:20 PM #17 Text 0 File DVDR.cpp, Line 2877
Recording mode: Sequential Recording Mode for Multisession
6:26:20 PM #18 Text 0 File DVDR.cpp, Line 3033
Start write address at LBA 0
DVD high compatibility mode: No
6:26:20 PM #19 Text 0 File Cdrdrv.cpp, Line 8995
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
6:33:41 PM #20 Text 0 File WriterStatus.cpp, Line 116
<E: _NEC DVD_RW ND-3550A> start writing Lead-Out at LBA 2138398 (20A11Eh), length 0 blocks
6:33:41 PM #21 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
6:33:42 PM #22 Text 0 File DVDR.cpp, Line 3273
EndDAO: Last written address was 2138383
6:33:45 PM #23 Phase 133 File dlgbrnst.cpp, Line 1730
Writing short lead-out
6:34:18 PM #24 SPTI -600 File SCSIPassThrough.cpp, Line 291
E: CdRom1: SCSIStatus(x00) WinError(121) NeroError(-600)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
Buffer x0369e000: Len x20
6:34:21 PM #25 CDR -600 File ThreadedTransferInterface.cpp, Line 1937
Device not available
6:34:21 PM #26 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1937
Could not perform end of Disc-at-once
6:34:22 PM #27 Text 0 File DVDR.cpp, Line 3273
EndDAO: Last written address was -1
6:34:22 PM #28 CDR -201 File WriterStatus.cpp, Line 167
Invalid write state
6:34:22 PM #29 TRANSFER -24 File WriterStatus.cpp, Line 167
6:34:22 PM #30 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 12x (16,620 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9464 bytes, created 8/15/2007 3:33:12 PM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 7/17/2002 9:53:02 AM
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 8/15/2007 3:33:10 PM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
====== *** Nero Burning ROM, History File *** ======
From what I see, the problem is here:
It appears your computer lost contact with your burner.E: CdRom1: SCSIStatus(x00) WinError(121) NeroError(-600)
And this a couple of lines later:That appears to be a communication problem.Device not available
That's a USB burner? Do you have other USB devices plugged into the computer? USB has a limited bandwidth. If other devices need to use the USB bus, they may interrupt the data transfer. I would unplug all other USB devices and see if that helps. The OS itself also can interrupt the stream to the burner. Anti-virus programs or some similar programs that are checking or accessing the USB bus can also cause this.
I would also try a different burning program on the off chance that it's something with Nero. ImgBurn can burn VIDEO_TS folders in 'Build' mode.
I don't think it's DVD media related. But it can relate to the USB chip set in your internal drive enclosure. That's a bit harder to chase down.
And welcome to our forums.
Thanks for the welcome.
I think its probably trying to go from the external hd to an external burner.
And thats because I was able to burn once and awhile.
The problem is my 30 gigs on my internal hd is pretty much full.
I think its time I clean up my hd and put the files to burn on the internal hd.
Thanks for the help!!!!!!
Brad -
Yes, a external HD through the computer to a external burner at the same time can be a problem.
If you can free up about 10GB on your internal drive and use that to transfer to your external burner, you should have better luck.
I didn't catch that you were using a laptop, but that explains a lot.
One option that may help is a PCMCIA card with USB or probably better, a FireWire output. Then you may be able to run both the drives at the same time without problems. External enclosures with FireWire and USB combos are reasonably priced and give you more options.
Try burning at 4x , not 12x .
Disable autorun for burner , its the one that normally trips up that sensor error when disc is almost completed .
Nero problem
By Doopopmercury in forum Newbie / General discussionsReplies: 8Last Post: 11th Apr 2012, 06:14 -
Whats a good cd/dvd burnig software to be used mainly if not only fot data?
By Denvers Dawgs in forum ComputerReplies: 11Last Post: 12th Jun 2008, 02:42 -
Burnig issues for making MTV styled CD/DVD. Looking for help.
By Andretti in forum Newbie / General discussionsReplies: 9Last Post: 27th May 2008, 22:09 -
DVD video burnig on asus rom
By tapal in forum Authoring (DVD)Replies: 0Last Post: 25th May 2008, 23:16 -
problem with Nero
By moe_b_disc in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2007, 05:13
