Hello All!!!
I'm a newbie to the forum and I would like to know which type of device will allow me to use my Laptop as a screen for my PS2 slimline. I purchased a USB instant VideoCD device on Ebay and although the capture area is reallly small, it does work. Next problem is that there is no sound. I get excellent little playing area but a bit dark and no sound. I know there is a way to achieve this I am just not sure exactly which device to use. I don't have a whole lot of resources right now so I'm kind trying to find an inexpensive means and nothing too cumbersome either. Something like a little connector type deal if at all possible!![]()
I'm not sure exactly what your "USB instant VideoCD" device is, but most capture hardware has inputs for audio and video. So you should have the video and audio of the PS2 connected to your capture device. The capture software, should have a step by step setup process which should include setting up and testing the audio.
Google is your Friend
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 16:15 -
Using my UK PS2 in the US
By ob7777777 in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2010, 22:36 -
Formatting laptop, how do i know if a laptop has wifi capabilities?
By ricardouk in forum ComputerReplies: 8Last Post: 21st Nov 2008, 09:24 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 19:40 -
using second laptop as a video in from laptop with broken display
By joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2008, 23:56
