Anbody know of a sottware app. that can magnify an image or zoom in on a point in the image andrefocus it where its viewable?? I've been looking for a while with no luck. I would imagine something like photoshop would do it, perhaps using an addin filter, but i wouldn't know how to begin doing something like that I have a still image as well as video that i want to zoom in on and refocus. Any help will be greatly appreciated. Thanks
Results 1 to 12 of 12
You mean like this:
That can be done in After Effects. Use the effect called "Magnify." -
Or perhaps this?
http://avisynth.org/vcmohan/EffectsMany/EffectLens.html
Originally Posted by Guiboche
People watch too much CSI (hehe, sorry, that wasn't a shot at you
But you can't refocus, or enhance an image anymore then what is available in it's original resolution. Sure, you can scale that image up, but you're just scaling up the bad pixels.
This magical program that turns big huge blocks into perfect resolution only exists in spy-fi TV shows and movies -
I was gonna post earlier that he better get ahold of the CSI guys but i thought i'd leave it alone 8)
But seeing as you broke the ground first :P -
yeah, i figured that would come up eventually. lol. tv screws up everything doesn't it??? LOL
Well, some things are possible, some are not. You won't be doing it with at-home software, that's for sure. A lot of this requires specialized custom-written code for each case. CSI tv shows use Photoshop and similar software with the menus jumbled and software interface obscured. It's largely fiction.
However, look at what Interpol recently spent months doing:
http://www.msnbc.msn.com/id/21190969/
If I ever decided to change careers, this would probably be my line of work.Want my help? Ask here! (not via PM!)
Start with a hi-res image. Make a low res copy. Zoom in on the low res copy, then crossfade to the same crop from the hi-res image.
Or if you can shoot again, shoot a wide angle shot. Shoot again with zoom. Start with the wide angle shot in your editor. Zoom into it. Crossfade to the zoomed in clip. Of course, if you can shoot again you can just zoom and manual focus. -
Original, rotated counterclockwise 550 degrees, then rotated clockwise 550 degrees:
Zoom H1
By Mac_Newbie in forum AudioReplies: 4Last Post: 5th Dec 2011, 21:40 -
Video techniques - shaking zoom in and zoom out effect?
By Mylo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 12th Oct 2011, 11:08 -
Zoom FireFox
By jollyjohn in forum ComputerReplies: 3Last Post: 26th Sep 2010, 11:20 -
How do i make a zoom????
By hostheking in forum EditingReplies: 5Last Post: 15th May 2007, 21:40 -
anybody know how to refocus a projection tv?
By tonydahose in forum DVB / IPTVReplies: 2Last Post: 6th May 2007, 08:52
