Any way to stop these annoying things from popping up on some pages? TIA
Results 1 to 9 of 9
With adblock plus you should you be able to block the vibrant javascript to load.
for firefox i use the adblock plus extension and have never seen one.
also use the noscript extension, just in case
edit: dang too slow on the keyboard sorry for the dupe.--
Doesn't noscript remove all javascript? Then it's crap.
only if you want it to. noscript is adjustable for every individual script on a page and remembers what you want to allow. like the script on your site
Block the following IP ranges in your firewall (or Peerguardian):
205.147.80.0/24
207.211.65.0/24
62.32.97.0/24
207.211.21.0/24
FYI, if your firewall only supports network/mask configs, use a mask of 255.255.255.0 (/24) If your firewall only supports ranges, use those .0 ranges and extend them to .255.
This will block all *known* Intellitxt/VibrantMedia sites.
You cannot use domain-based filtering on Intellitxt unless you have something like DNSKong or DNSredirector running using "intellitxt" as a key. Good luck getting either of those to run on XP and above...
Hope this helps.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 08:08 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45
