hi, iīm using the TMPGEnc DVD Author 3 a great tool but I realy have a problem with the menu system.
How I make a "return to movie" button ?
I want return to the movie (not started again) without press the "menu" again, just need a button to make that.
The movie will play in DVD player only.
Results 1 to 14 of 14
I don't believe that any created menu will do that as there would have to be an index, a chapter if you will, for every frame so it would know where to go back to . Usually to resume a movie it is the function of the DVD player (hit pause or stop on the remote and then press any key to get back to where you left off). Chapters in menus are the key points of hopping back into a movie.
Relayerman
EDIT: I stand corrected. It CAN be done. -
It can be done, but I don't believe that Tmpgenc DVD Author is sophisticated enough to do it. When you hit the menu button, the current location in the title is stored to a register, and you can resume to it. DLP supports this feature, but most entry level (which Tmpgenc DVD Author is) tools do not. It may be possible to add such a function with PGCEdit, but I couldn't tell you how.
Read my blog here.
well, first thanks for reply guys...
The image tell what I need.
Extract from : LOST = first season vol 02
The "return to episode" button just exit the MENU and return to movie.
Telling in another way, I need to hidden the MENU.
First make a button like that in Author. I am not familiar with that software, but hope it will let you do that. Link it to movie or enythink you want.
Compile project
Open in PGCEdit
Find your Menu (Left side window in VTSM#, LU#) by clicking on it it will show in window.
Once you have that, click on Menu icon, upper toolbar (green Icon)
Click on button you want to edit, than click on bar bellow where it show command
New window come up, click on "By Type-Link to-ResumeRMS(on the bottom)" click OK
Close and save changes.
It is done -
At authoring you'll need to create an extra fake chapter to have that button; if you use text buttons, give it a proper name.
If you use DVDRemake, right/click on that button => edit button commands => select 'set instructions' => use 'Resume'. Then export modified files and replace ifo's. You can previously 'export test DVD' to be sure. -
hummmm...
...Dvdremake ...
I think this way is more easily to view the files.
thanks Alex.
but if not I will try the PGCEdit.
Realy thanks to everyone. -
ok, letīs close this topic
I compiled my movie with TMPGENc and after that I open the PGCEdit tool and I make a test with the [SETUP] BUTTON in the MAIN MENU and change the command line to "resume".
ITīS WORKS FINE.
Muito obrigado
muchas gracias
arigatou gozaimasu
thank you very much -
De nada!ITīS WORKS FINE.
Muito obrigado
muchas gracias
arigatou gozaimasu
thank you very much
I gave you PGCEdit because it is free, but myself I use DVDRemake Pro to do this. I found it easier to navigate in it.
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 11:00 -
TMPGEnc Author Version 2.0 - Unable to make a DVD with a motion Menu
By tug_hill2 in forum Authoring (DVD)Replies: 5Last Post: 28th Sep 2007, 01:37 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43 -
TmpgEnc DVD Author 3 - Question About Menu Music
By heyjjjaded in forum Authoring (DVD)Replies: 10Last Post: 30th Jul 2007, 14:16 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 04:53
