Hej.
I have made several tape with my old analog videocamera, I have difrent marks of tape, sony, fuji, tdk, and more, I have been making these tspes over several years, and this camera dont exist any more, but I have an adabter, then I can play tmen in a videorecorder.
Some of the tapes are ok, but others I cant look what is on them, the sound is ok but if there is an pickture it is disortet, have I lost whats on theese tapes or is there any way to resower it.
I hope that someone can help me. Thanks
svaage
				Results 1 to 9 of 9
	You have a sample of the capture?
 If by distorted you mean it's skewing a TBC might help but it may also not help. Providing a smaple clip will give everyone something to look at...
	What kind of analog videocamera?
	I had a JVC VHSc, video recorder, I have tryed it in GR-AX7, it is not the same that I lost, some of my tape there is no problems with, I have tryed to make at small test, I hope that it is working, it is a small zip file.
 TBC is that some kind of hardware ?
 svaage
 test.rar
	I also had a JVC VHSc camcorder and had a similar problem. If memory serves the one of camcorder's modes recorded in S-VHS format. Tapes recorded in that format will not play on a standard VHS. When my camcorder died I picked up a S-VHS VCR which plays the tapes just fine.
	I dont know what format I record the tapes in, I think that it was standard, I have tryed to play them in an philips vr 550 video recorder, that was very bad, then I tryed an Normende spectra video recorder ( the test was made in this one ), then I tryed to play in the jvc camera, no luck, there is no folder in the tape they look ok.
 svaage
	It might be S-VHS-C Want my help? Ask here! (not via PM!)
	If it is s-vhs-c, how can I play it, I am using an VHS-C adapter, and a NORMENDE spectra videoplayer, and a s-vhs cabel to pc, is it the videoplayer I have to change ??, is there anyone there can advice me
 svaage
	You have to have a player capable of playing S-VHS content.
 There is no such animal as an "s-vhs cable". That is an s-video cable.Want my help? Ask here! (not via PM!)
  Capturing Videotape that has closed captionsBy ian c-nall in forum Capturing and VCRReplies: 22Last Post: 4th Aug 2013, 23:33
  8mm Videotape Playback issues on Sony VTRBy nazopo in forum MediaReplies: 1Last Post: 22nd Dec 2010, 20:47
  Creating 4/3 resolution DVD - Should I videotape it in HD or SD?By chebba in forum Authoring (DVD)Replies: 7Last Post: 13th Dec 2009, 10:24
  capturing video from a vhs videotape player to PCBy kasfig in forum Capturing and VCRReplies: 7Last Post: 10th Mar 2008, 10:19
  Playback standalone VHS videotape player through PCBy kasfig in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2007, 16:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
