I can't get Ulead to accept avi files for some reason.
Results 1 to 16 of 16
Are you sure they are AVI files???
Or are they "something else"....?? -
The extension is .avi. I was able to get the files into Ulead but it won't let me view the video and only the audio of it is playing.
how is that really gonna help? Its an avi file and I can't get the video to work in Ulead.
"DVSD" is standard DV video, but according to FourCC.org "dvsd" is DV generated by a particular firewire card, and needs the card present to be used. This seems odd. Can you confirm that the dvsd is lower case and not upper case ?
XP ships with the microsoft DV codec as standard, so you should be able to read and write standard DV through any DirectShow aware software. Something screwy is going on with your system.Read my blog here.
DV format usually comes from a camcorder or other DV source and is large (~13GB/hour). Does this seem like what you have?
Video Studio 10 is happy to accept DV format. -
VS10 will take the avi files into it but the videos will be black and only the audio is playing...
Try loading it into Windows Movie Maker , to see if its only Video Studio .
You can also download this short 10 sec clip to see if it works (36MB):
http://www.nepadigital.com/reencode/avidv.avi
Thats a DV-AVI clip, note that the sound track is blank. -
yes I do have FFDShow installed.
I also tried Windows Movie Maker and it says "The file cannot be imported because the codec required to play the file is not installed on your computer. If you have already tried to download and install the codec, close and restart Windows Movie Maker, and then try to import the file again."
Ulead video studio 8 help
By the big man in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jun 2009, 17:02 -
Ulead Video Studio 9 - colorspace
By Froddy1 in forum EditingReplies: 0Last Post: 2nd Feb 2009, 11:49 -
Ulead Video Studio 11 (to dvd)
By Firesign in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 13:23 -
Does anyone use ULEAD Video Studio 10?? or any suggestions?
By cmlmich in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2007, 23:12 -
Ulead Video Studio 7 SE
By uricktam in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 12:14
