xxxxxxxxxxxxxxxxxxxxxxxxxx
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 7/22/2004 12:33:44 PM
Nero API version: 6.3.1.26
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Results 1 to 10 of 10
DVD Shrink uses either Nero or DVD Decrypter to do it's burning. In your case, it's Nero, and it's not happy. I gave up using Nero years ago, so I can't give you any specific fixes for this problem.
Personally, I would write the results to a folder on the HDD (option in Shrink backup), then burn with Imgburn.Read my blog here.
Soccerman77, I blanked out your Nero serial number. Not really a good idea to post it on a open forum.
Is what you posted part of your Nero burning log? If so, there's a lot more to it. I'm not seeing any error.
Most times Nero errors are with the actual burning and in the bottom third of the log. You could take a look at the Doom9 forum. They have a good guide for Nero errors. http://forum.digital-digest.com/showthread.php?s=&threadid=45942
I can tell you, the majority of Nero errors seem to be DVD media related. I usually suggest trying a different brand.
But I'm just guessing until you can give us more info or post your Nero Burning log.
I will try to make clips from a DVD, when I use shrink I will use the instructions given here. All is well and the clips are made right, but after I backup it comes up to eject disk and then the error messages comes up.
You would need to give the exact text of the error. Dose Shrink work properly when you just do a simple backup of a DVD?
Don't use NERO to burn your files from DVD SHRINK. Use IMGBURN.Originally Posted by Soccerman77
Or try to find DVD_Shrink_3_2_b_w_IB.zip. It will let you burn with imgburn straight from dvd shrink.
Ok, when I hit backup,I usually save to my desktop. It saves in VOD form.
Server error when running Install of DVD Slideshow GUI
By ROGUTAH in forum Newbie / General discussionsReplies: 5Last Post: 17th Jan 2012, 19:51 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 16:59 -
DVD Shrink - dvd won't open - 'invalid navigation' message...what to do...
By bahjan in forum Authoring (DVD)Replies: 7Last Post: 12th Mar 2010, 08:01 -
How can I shrink down the running time of an audio file?
By darkzero297 in forum AudioReplies: 3Last Post: 16th May 2009, 13:07 -
Weird error message with DVD Shrink
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 31st Jan 2008, 19:12
