I was wondering if any of the guros out there could help me out by writing me a script to accomplise this
At the moment I am recording my TV with a DVB-T card using DVB Web Scheduler and the resulting recorded TS files are then put through Videoredo and output as MPG with NAV Packets, which then I load into GUI for DVD Author and then make a disc up ready for my DVD Player.
Now what I am needing to do is take a directory of files that are 4.37 gig in size and with script of some sort
or bat file like, click it so that it will put them into GUI for DVD Author using the default basic menu and then
use the file name as the program
then make a ready DVD Folder layout Video and Audio_TS ready to be burnt later on or poss even then burn with IMG burn.
At the moment i have alot of mpg files ready to be burnt off onto discs and am finding doing it manually is taking alot of time to make the dvd structures up
here is an example of a file name and its corresponding chapter info
The Life of Birds (Meat-Eaters) UKTV History (2007-10-11 13-50-Thu).mpg
The Life of Birds (Meat-Eaters) UKTV History (2007-10-11 13-50-Thu).txt
THe file names would then become the text to highlite and start the program again with the standard blue background (DVD Text Menu basic)
Any help would be appriecated
Thanks Alot
Beardedboss
What you need to do is look at the scripts that GUIForDVDAuthor creates, either for DVD Author or Muxman (whichever you normally use), and replicate those. I don't believe you can drive GUIForDVDAuthor by script, however GUIForDVDAuthor is a front-end to tools that can be scripted. Look at what GUIForDVDAuthor does, and use that as the basis for your own scripts.
That said, you may also need to learn some basic pearl or similar in order to manipulate the scripts dynamically.Read my blog here.
GfD has some simple command line parameters, which could be used to start it with the video + audio + chapter files. But there are some more things to do...
If you want to run it 'batch like', each project needs a different output directory. If you want to burn the disk automatically, you would need several burners, or you need to change it manually after each burn.
The most easy approach would be using the GfD command line to start, set the output directory, 'Create Batch' for as many 'DVDs' you like (and have the HD space for). Create a 'Master Batch file' and run it.
There are several possibilities to do some kind of scripting to automate also this procedure. I would probably try it with AutoIt.GUI for dvdauthor:
https://www.videohelp.com/~gfd/
DVD slideshow GUI - size/DVD issues
By RichU in forum Authoring (DVD)Replies: 6Last Post: 28th Mar 2011, 23:54 -
DVD Structuring Problem using GUI for DVD Author
By DesertAvenger in forum Authoring (DVD)Replies: 2Last Post: 2nd Sep 2009, 01:58 -
In GUI Dvd Author-my finished dvd has no sound on the menu in some players?
By extent in forum Authoring (DVD)Replies: 3Last Post: 2nd May 2009, 04:19 -
online database to help automate DVD encoding - useful?
By CBass in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2008, 17:10 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03
