I have a pal avi that I am trying to convert to ntsc dvd. I used virtualdub and changed the video framerate and then encoded it with main encoder. Everything went great with the video. I used virtualdub to extract the audio to a wav file. I then used goldwave to convert it to ntsc by setting the timewarp to 95.904%(23.976/25.000). I use TMPGEnc DVD Author 1.6. to author the dvd and convert the audio to DD on the fly. When I inserted the chapter points I noticed that the sound was coming about a second too early. I used virtualdub and selected the interleave setting and set the audio delay to 979ms. After converting it to ntsc I found that the audio delay is exactly the same. Any ideas what I am doing wrong and how I can fix this? I have used this method before and it worked great but this time I have no idea what is going wrong.
Oops! My bad! I figured out what I was doing wrong! Duh! I need to convert to ntsc first with goldwave and then change the interleave via virtualdub.
Audio sync issue, Virtualdub, old video clips changing frame rate
By litmus in forum Video ConversionReplies: 1Last Post: 19th Sep 2011, 11:35 -
VirtualDub Sync Issue
By EzK in forum EditingReplies: 1Last Post: 13th Jul 2011, 11:30 -
Audio Sync issue?
By tb582 in forum Newbie / General discussionsReplies: 3Last Post: 18th Jan 2011, 11:25 -
Audio sync issue with
By 123fish123 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2007, 17:54 -
VirtualDub Audio Sync Issue?
By hech54 in forum EditingReplies: 2Last Post: 10th Jun 2007, 04:41
