Here's my scenario: I have an unmodded XBOX 360 (Premium version). I would like to play DVD movies on it. It plays storebought DVDs without a problem. It plays DVD-Rs of backed movies that I have downloaded via bittorrent. I also use the Winavi program to create DVDs from avi files. This is where my problem begins. The XBOX 360 will not play these discs for some reason. My normal DVD player will, though. Why is this? I have tried burning the DVD-R data disc as normal with the video_ts and audio_ts folders, and also creating a disc image with those folders, and neither works in the XBOX. Any ideas? Thanks so much in advance!
Alaska Joe
Maybe a PAL/NTSC issue? Or try convert and burn with another tool like DVD Flick or ConvertXtoDVD.
Sorry for excluding that info - 16x Memorex DVD-Rs is what's being used. Like I said though, one burned disc that was already in .img format worked fine, but the ones I converted did not. Both were on the same Memorex brand discs. I have tired burning using Nero and DVD Decrypter. Burns of readymade DVDs that would be considered "backups" using Nero and DVD Decrypter have worked just fine in the XBOX - it's not until I convert avi files into DVDs that I have the problem. Using WINAVI as the conversion program to go from avi to DVD.
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 02:05 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 06:19 -
Xbox 360 HD-DVD Player on PC
By WiReTaP in forum User guidesReplies: 48Last Post: 26th Dec 2008, 12:35 -
Can you interchange a xbox 360 hddvd drive between pc and 360?
By yoda313 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2007, 09:06 -
xbox 360 hd dvd addon
By tk69045 in forum Media Center PC / MediaCentersReplies: 0Last Post: 31st Jul 2007, 13:59
