Hi, got a couple of original music dvd's that after playing each song it goes back to the main menu.
Is there a way with IFOEDIT to the play the songs all together?
Useful, thanks.
But I'd like to keep the original menus, is there any way? -
Pgcedit, but it doesn't look that simple if you read http://www.romskye.com/GP/gp003playselect.pdf
This can be done with DVDRemake. The solution depends on how exactly playback is organized on DVD.
The usual way of making multiple songs go to menu after playback is using cell commands in the last cell of each program. If so, then those commands should be deleted and each program registered as a chapter of the same title.
Sony Vegas Pro 9: Batch Render Clips Separated by Markers
By mltwitz in forum EditingReplies: 0Last Post: 5th Apr 2010, 15:41 -
DV to a format that play in QuickTime and standaloneDVDplayer with chapters
By DavidCasillas in forum MacReplies: 3Last Post: 20th Sep 2008, 21:28 -
Joining separated episode from VTS VOB file to AVI
By submerge in forum ffmpegX general discussionReplies: 51Last Post: 7th May 2008, 15:47 -
Getting chapters to play automatically
By AlleyCatty in forum Authoring (DVD)Replies: 4Last Post: 16th Oct 2007, 15:59 -
How to merge separated dvd's?
By JConnor in forum Newbie / General discussionsReplies: 7Last Post: 9th Jul 2007, 03:34
