I am following the guide to using Subtitle Creator Wizard and the guide says I need "mpeg2/DVD decoder".
Can someone recommend a particular freeware "mpeg2/DVD decoder" that will work with Subtitle Creator Wizard? Also, is mpeg2/DVD decoder one software, or two separate softwares?
Also, it is completely necessary to install an mpeg2/DVD decoder to use Subtitle Creator Wizard?
I already have Power DVD, Media Player Classic and KM Player installed and I am worried about a possible software conflict if I install too many things.
No, it's not necessary you just wont be able to preview the video in subtitle creator.
Problem with subtitle creator 2.2
By ashkan_vpm2 in forum SubtitleReplies: 0Last Post: 1st May 2010, 17:43 -
Subtitle Creator - Unable to set Default Subtitle Colors & Default Prof
By blue2 in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 22:47 -
Subtitle colours in subtitle creator
By Belfour in forum SubtitleReplies: 3Last Post: 22nd Oct 2009, 02:00 -
Subtitle Creator noob
By Kuda in forum SubtitleReplies: 1Last Post: 3rd Oct 2009, 02:23 -
WMV to DVD and problem installing Easy Media Creator 10
By jhayes in forum Video ConversionReplies: 3Last Post: 10th Mar 2008, 14:26
