    Oct 2007
    Hi have a bunch of video files filmed on my phone that i wish to put onto DVD.
    I'm trying to be (a little too) clever and add a menu to choose between them.
    - The files are all formatted and work brilliantly on DVD on their own.
    - I have used DVDstyler to make a menu, I have added the video files and buttons to move between them etc.
    The problem i have is that the Burn option on DVDSTYLER doesn't work, and once i've saved the DVD project i can't find a way to burn it to disk.
    Is anyone able to offer any help?
    Phil
    Locate the output folder, the VIDEO_TS folder and just burn it with Imgburn, http://forum.imgburn.com/index.php?showtopic=4632
    Oct 2007
    Thats what i originally thought, but saving the DVDStyler menu with the films attached is just an XML document.
    Should i burn the XML document AND the DVDoutput folder onto the same disk>?
    No, just the VIDEO_TS. It should contain vob,ifo and bup files, if not then something is wrong.
