I Have a dvd and I want to make a avi file for it, back cover of dvd box says WIDESCREEN Version and preserves the original 1.85:1 theatrical aspect ratio, my question is do I encode at 1.85:1 with a resolution of 592x320 or use a aspect of 1.78:1 with a resolution of 512x288 or can I encode both ways.
He's making an AVI. I'll grant you it's a somewhat misleading thread title.
You crop away the black bars and then resize based on the original DAR (either 16:9 or 4:3, in this case it sounds like a widescreen 4:3 DVD) Don't blindly make your resolution either 1.85:1 or 1.78:1. Make it what it is on the DVD. The information on a DVD box is sometimes wrong. I use Gordian Knot's Resolution Tab for opening the D2V and cropping and resizing to a good resolution, but there are other ways as well.my question is do I encode at 1.85:1 with a resolution of 592x320 or use a aspect of 1.78:1 with a resolution of 512x288 or can I encode both ways.
Change DVD aspect ratio
By drgt in forum Newbie / General discussionsReplies: 11Last Post: 4th Oct 2010, 21:45 -
Aspect ratio changer for DVD?
By vato76 in forum Authoring (DVD)Replies: 3Last Post: 23rd Jun 2010, 01:29 -
VLC DVD aspect ratio
By vhsreject in forum Software PlayingReplies: 3Last Post: 21st Sep 2009, 10:12 -
Changing a DVD's Aspect Ratio
By soneman in forum Authoring (DVD)Replies: 11Last Post: 8th Sep 2009, 18:18 -
AVI to DVD with different aspect ratio
By germ in forum ffmpegX general discussionReplies: 16Last Post: 7th Apr 2008, 22:50
