I am new to cce 2.5 even though i used it before. I just made a vbr vcd ,minus the audio, but the mpv file is blank just black and nothing else. It took me 13 hours to do this and now i can't view it. I was going to just convert the wav from the avi with tmpgenc then multiplex it with the mpv. I usually use Tmpgenc but now everytime I try to open my frameserve avi file it crashes, even if i merge the aviproxy off then restart then merge it back on. This is so annoying because tmpgenc usually doesn't give me problems unless an occasionaly frameserving problem comes up.I tried opening the MPV up in tmpgenc but it said some kinda error. Anyway is there anyway to fix my MPV file that is just black, I can't see any video at all. I would hate to think I wasted 13 hours on a 3 pass vcdanyway thanks
I don't know your problem is with CCE or with TMPG. I guess you encoded your .mpv file with CCE that you can't open with TMPG. If you just want to view your .mpv file to see if it's OK, you can use other programs to do that, maybe Windows Media Player, or others. I always do that. I don't know why your frameserve didn't work. But if you want to extract .wav file from your .avi file, you can do that directly wth V-Dub, then you encode it to .mpa for multiplexing.
BTW, most people only use CCE to do mepg-2 for SVCD, not VCD.
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 20:14 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 12:03 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 14:41 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 19:47 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 20:13
