Splitting a cell usually works fine, but rarely (such as right now) if I split a cell very close to the end of a movie, the movie ends at that point (unless I skip past it) and goes back to the menu. Chapters made earlier in the movie are fine. When I open the movie in the Pgcedit editor window, the only thing unusual is the "Seemless joint" box for that cell is colored pink (meaning "Must be clear after a cell command"). Type Flag is the nominal "8". I unchecked the box (so no longer pink) but no change. If I open the movie back in Vobblanker, the new cell has in the CAT column (which I assume is the same as Flag Type) "0A" instead of "8" like the other cells. There's gotta be an easy fix for this, right?
Just noticed the "Cell Command" column in Pgcedit editor; changed it from 1 to 0. Problem solved.
Results 1 to 1 of 1
VobBlanker substituir o menu/How to replace DVD menus with VobBlanker
By escarlate in forum Authoring (DVD)Replies: 24Last Post: 31st May 2011, 02:52 -
Adding Chapter Markers
By Big Jake in forum Authoring (DVD)Replies: 11Last Post: 12th Sep 2010, 00:50 -
VobBlanker
By jjis in forum DVD RippingReplies: 2Last Post: 5th May 2010, 19:03 -
Glitch at Chapter Break in MPG/VOB
By ironorr in forum Software PlayingReplies: 0Last Post: 29th Dec 2008, 16:49 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 12:51
